I recently ran into a very stupid mistake and or test. There were two thirty amp disconnects 3 phase mounted in a basement utility room for 2 commercial washing machines , nothing unusual until I looked at the back of the disconnects and they both had 3/4" pvc ran out of the back of them and no 10 wire terminated to the load side this was obviously wrong after seeing they were back to back . Where did they go? they were mounted to poured in place concrete wall. I pulled on the wires and the conduits were ran back to back between each disconnect about 8 feet apart. I see one circut for both washers nooooooooooo.My coworker said you can run circuits through the disconnects , I said no way just not a practice I have ever seen. I could not find anything in the code book , is he right? can you run a circuit through the disconnect to the next and be in compliance ?
