DBoone
- Mississippi
- General Contractor
My boss had me install a new range today in an old house. When I met him there the old range was gone and we just had the cable coming out of the wall. The cable was #6 SE, XHHW. It only had 2 ungrounded conductors and a grounding conductor, no neutral. I raised concern about not having a neutral because I did not want to use the uninsulated grounding conductor as the neutral. My boss is old school, having been in the building trade for 30 years and he is under the impression that in the past all that was ever used was 2 hots and a ground. I have to admit that I'm sure in small town Mississippi incorrect electrical "knowledge" has been passed down thru the years. My boss cares deeply about the houses he builds but I'm afraid some aspects of his electrical knowledge are flawed based on "this is the way we've always done it". I knew this range was getting installed with the cable provided whether I did it or refused to do it and possibly lose my job so I installed it. The ground strap is in place and the grounding conductor is landed on the neutral terminal. I'm trying to learn the proper ways to do electrical installations and I'm having to fight the incorrect "this is how we've always done it" mentality along the way. What would y'all have done, refuse to do the install and possibly lose a job or realize that it's getting installed whether you like it or not, and therefore go ahead and install it and just know that when you're doing your own work you'll do it the proper way. Thanks for letting me vent.
