Has anyone done one? A friend bought a rental prop with an in-law apt. The main panel in the crawl space has a 100amp breaker feeding the in law apt sub panel. Looks pretty easy except he wants the metering device upstairs somewhere where he can read it. The site doesn't show a picture of the single phase 100 amp install. The 3phase shows ct's around the mains and leads off the breakers.
i have two of them to do next week.
sign companies almost always have them installed
for metering. single phase 20 amp 120volt units.
LED channel signs don't draw much anymore.
just called my wholesale house... a 100amp/3ph 208V
emon is about $550 with tax. they make remote monitoring
units that can tie to an IP over a LAN, or to client software
running anywhere....
i suspect it's expensive enough to discourage your customer
into walking out to the meter. you can probably find out here....
? Class 2100-Wireless Three Phase Meters
one thing i've found helpful, 'cause there usually isn't anyplace
near the panel to hang one of these in a high rise, as there are
already six of them festooning the wall around the panel, is
a LB and a LR, and float the emon between them. if you snug
everything up tight, it works well.
