Fulthrotl
~Autocorrect is My Worst Enema.~
- E
i have an interesting problem, sort of.
i have a flow switch in a fire alarm system, in a 4" riser,
that is amazingly sensitive. any pulsation in the fire
water pressure flutters it, and gives a false alarm.
the grading contractor was compacting lifts of road base,
using an 1 1/2" hose off the fire hydrant, and when a truck
would run across the hose, the pressure wave will flutter
the flow paddle enough to give a closed switch for about
three seconds.
not a big deal, before the system was commissioned and
put on line. today, i was using a 1 1/2" hose to fill a sewage
lift station to test floats and put it online.... every time i
turned off the hydrant, the alarm was set off... and i was
closing the valve a third of a mile from the flow switch....
this was brought to my attention after the fourth alarm. :dunce:
(you can't hear a fire bell a third of a mile away when there
is a tugboat idling next to you.)
any suggestions to calm this thing down? i'm considering tensioning
up the springs, if possible... i haven't ripped it apart yet to see if
i can hurt it... that is tomorrows adventure.
almost all suggestions appreciated....
three seconds.
