If you have an existing 200A service with a meter can an gutter with a 150A panel with main breaker an a 100A fusible disconnect an wanting to install a 200A Transfer switch for a portable 60KW Generator does the transfer switch need to be fusible. I understand that the transfer switch will become the service disconnect an the existing panel an existing disconnect will become a feeder. Just wasnt sure if the transfer need overcurrent protection
