- Placerville, CA, USA
- Retired PV System Designer
The point is that turning the unit off using the obvious switch (brew on/off) rather than a disconnect does not insure that the holding tank heater will not start drawing current at an unpredictable time. But it would not be a continuous load in terms of ampacity calculations.And when the tank reaches the set temp it turns off. If they were always on it would eventually boil the water, and by boil I mean we would have high pressure steam start developing in there, if it were not used fast enough.
