pmsbpfjc1
- fall river, ma bristol
Do you need a afci on a laundry circuit? I don't see that requirement
If your laundry is in a area considered unfinished then it need not to be AFCI protected. But then it would need to be GFCI protected.
I have never seen anything in the NEC that states what you are saying. Yes if your laundry was in your bedroom or another room that needed afci then yes it would.
In the 2014 both kitchen and laundry rooms will be required to have afci protection
It's about time they decided to put a stop to all of those laundry rooms bursting into flames....In the 2014 both kitchen and laundry rooms will be required to have afci protection
:lol::slaphead:It's about time they decided to put a stop to all of those laundry rooms bursting into flames.
Not required........yet.
Nope. 2014 needs afci in laundry and kitchen- If the washer is in the basement then IMO it would not need afci unless the room is designated laundry but that would be a fight with the ahj.He might be talking about an unfinished basement.
That is truewe are going to install GFCI protection in the "Laundry Area" as well along with AFCI.
