Joe Crecca
- New Jersey
I am installing two sma 6000 inverters with 30amp 2 pole breakers. I have a dedicated 100 amp subpanel box for the inverters. The box has a 100 amp main breaker and is line side tapped to the 200 amp service feeders after the meter. I have installed many systems this way. The DCA inspector is saying we are breaking the 120% rule. I thought that if you had a dedicated sub panel labeled for solar back fed only that it was okay to fill above the 120% rule. Please any information pertaining to this would be helpful. I have to have a cumulative srec meter and need to combine the ac output of all the inverters into one ac 240 volt source. I have always done this by a sub panel line side tapped. Thank you
