mstrlucky74
- NJ
Are there cam locks that accept aluminum cable? I was told no because all cam locks are brass and that with Al wire won't work.
I would look at the instructions that come with those connectors over what someone told you.
I looked at what I have available and it does not specify aluminum or copper. Just wire size.
Can locks are for portable power cable, where are you getting aluminum portable power cable?
What about the stationary side of the portable cable connection? Or will it always be a pigtail?
I agree. All of the panel mounted ones I have seen have a threaded stud/nut so you can put any standard CU or AL lug on them.Panel mount camloks have a threaded brass stud, so you should be able to use any lug that accepts aluminum and is also compatible with brass (which should be just about any cu-al lug). ETA- I can't imagine using aluminum wire/cable into a cable-mount camlok, kind of defeats the "flexible" concept.
monster cable being among them.
Where did you tap the power from? If fully loaded that would be 375kW, so I hope that the diversity factor helped.About 150 20 amp 125 volt circuits needed in a parking lot that had none.
I am babysitting cam locs today .... and yesterday as well. Taking care of power for a food show. About 150 20 amp 125 volt circuits needed in a parking lot that had none.
No aluminum here though ..
except at one of the first CES's in vegas, they *melted* an aluminum
core on a 500 KW dry type transformer.... i suspect overcurrent protection
was not in use, just a multiple 4/0 tap off a main bus... that gets done a bit.
i know that six 4/0 cam locks per leg will pull a megawatt without getting all
that hot... but it does get pretty warm.
