I'm hoping someone can answer the following. The link below says that I can meet NEC 240-6(c) by sealing the trip unit.
http://www.schneider-electric.us/si...&country=US&lang=EN&id=FA120964&redirect=true
"Yes, the 400A DJM circuit breaker has an adjustable AMPERE RATING feature allowing the trip settings to be dialed down from 400A maximum to 160A minimum. A Tamper-evident seal kit is also available for this DJM circuit breaker by ordering catalog number: 29375. This seal kit meets NEC 240-6(c) requirements. Refer to PAGE 12 & 13 of the following document for details on how to dial-down the ampere rating of this DJM circuit breaker.
http://ecatalog.squared.com/pubs/Circuit%20Protection/Molded%20Case%20Circuit%20Breakers/Merlin%20Gerin%20Molded%20Case%20Circuit%20Breakers/06"
However, can I avoid using GFP under 230.95 by using this method?
230.95 Ground-Fault Protection of Equipment.
Ground-fault protection of equipment shall be provided for solidly grounded wye electric services of more than 150 volts to ground but not exceeding 600 volts phase-to-phase for each service disconnect rated 1000 amperes or more. The grounded conductor for the solidly grounded wye system shall be connected directly to ground through a grounding electrode system, as specified in*250.50, without inserting any resistor or impedance device.
The rating of the service disconnect shall be considered to be the rating of the largest fuse that can be installed or the highest continuous current trip setting for which the actual overcurrent device installed in a circuit breaker is rated or can be adjusted.
