suspending of a 45 Kva XFMR?
Jeff C
LA, Calif.
I am looking for info on suspending a 45 Kva Xfmr in a T-Bar ceiling, I am looking for info on how to lift the Xfmr, the room is very small and I only have a 36" door to get a lift into the room?
Thanks Jeff
don_resqcapt19
Illinois
retired electrician
If you are going to suspend the transfomer, then you should be able to rig off of the structure that the transfomer will be suspended from. If you are going to wall mount it, you may be able to use a lift like the sheet metal guys use for duct work.
infinity
New Jersey
Journeyman Electrician
We use a Genie lift or in really tight spots a 1/2 or 1 ton chain fall. A 45 kva should be no problem to suspend with some rod and strut.
GoldDigger
Placerville, CA, USA
Retired PV System Designer
Don't hesitate to rent the right equipment if you do not have it.
Trying to "make do" when heavy loads are involved can end up taking more time as well as being unsafe.
If nobody on the job has any experience with rigging, a chain fail and improvised support can be risky too.
Obvious, but I had to say it....
infinity
New Jersey
Good point. Even a lift can be dangerous if not used properly.
