In a test question like this it is easy to get confused as you have to find the resistance of each resistor the rated values given, such as the 130 volts for the TV and 110 volts for the toaster as well as the 250 volts for the water heater, but then with the known resistance of each resistor you must find the correct values at the voltage supplies which was given at 240 volts using ohms law.
Once you know to resistance of each resistor you can start filling in the missing items of each resistor at the supplied voltage.
To find the voltage drop across each of the series resistors you must find the total resistance of the series circuit, then you must find the current in this series circuit by dividing the supplied voltage by total resistance, this will give you the current (I) that you divide each loads resistance into, this will give you the voltage drop of each load in this series circuit, the parallel water heaters values will not affect this outcome, as it only adds to the total load on the supply.
So heres what you must solve:
I filled in the given values.
Toaster = R1
TV = R2
Water heater = R3
R1
E1= _110v__
I1= ____
R1= ____
P1= _700w__
R2
E2= _130v_
I2= _13.4a_
R2= _____
P2= _____
R3
E3= _250v_
I3= ______
R3= ______
P3 _47000w_
Now after finding the above missing values solve with the supplied 240v voltage by filling in the found resistance for each of resistors above in the spaces below, solve R1 and R2's total resistance and divide it into the supplied 240 volts to get the R1 and R2's total current, then multiply this current by each resistors resistance to get the voltage drop across each resistor in the series circuit, check your work by adding the two voltage drop to see if it equals the supplied voltage of 240 volts.
E1=
I1=
R1=
P1=
E2=
I2=
R2=
P2=
E3= 240 volts
I3=
R3=
P3=
I tell the test takers that drawing the ohms law circles one for power and one for ohms at the top of their work sheet can make it easy to reference while they are working the problems.
