Southwire Type MTW/TEW or AWM is used for machine tool wiring and internal wiring of appliances. Typical applications
include wiring for refrigeration equipment, air-conditioning equipment, control wiring of machine tools, automatic washers, etc.
Type MTW rating permits use in (i) dry locations not to exceed 90?C (ampacity is limited to 75?C conductor temperature per
NFPA 79); or (ii) wet locations or other applicable locations when exposed to oil or coolant at temperatures not to exceed
60?C. Type TEW rating permits use in (i) dry locations not to exceed 105?C; or (ii) wet locations or other applicable locations
when exposed to oil or coolant at temperatures not to exceed 60?C. When used as AWM, intended uses are limited to dry
locations at temperatures not to exceed 105?C (applicable to both UL and CSA ratings). Standard product is marked Style
1015 and various other styles.
