- Illinois
- retired electrician
That is not a valid test when using non-contact voltage tester, unless all of the conditions between the know live source and the source being tested are exactly the same. It would be very rare where the conditions would be exactly the same. Sure it does prove that the tester works on the know source, but does not prove that the test source is not live as the differing conditions may give a false negative on the source being tested. Other types of testers do not have the same condition issues as the non-contact testers do....
It is imperative that the testing device be checked by testing on a known energized voltage source first, then checking the circuit in question, and then verifying that your testing device is working against a known energized voltage source. I have a fluke non contact tester and I. Never trust it to be working unless I test it by checking a know energized voltage source. ...
