A friend's office has 20 PCs, the boss wants to have a portable gasoline to power all these PCs in case building loose utility power.
Max. amp draws per PC and screen is 8A.
(20) PCs at 120V will consume = 20 x 8 x 120 = 19.2kVA
Assume generator pf = 0.8, the generator rating will probably = 19.2 kVA x 0.8 = 15.4kW
Does anyone know any generator manufacturer make this size (or larger) of portable gasoline generator with 10 output outlets (20A, 120V)? (They are trying to connect two PC to one generator output outlet via plug strip).
Any other solutions or suggestions for this? Thank you.
