service breaker panel wiring
dsalmons
New member
upstate new york
Need to know what wire size and type to use. I have a main 100 amp disconnect switch outside the house and need to run feed cable approx 50' to 100 amp service breaker panel. I would like to run up the outside of the house to attic level then penetrate house and run threw attic and down threw frame wall to top of service breaker panel which will be recess mounted in wall. Can I use 2/2/4/6 or 2/2/2/4 aluminum for this application
jumper
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
