Spa feeds
James S.
Mesa, Arizona
Is there any reason you can't use romex to feed an outdoor spa or pool sub panel on a house? I keep seeing conduit in attics and it is making me second guess myself.
augie47
Tennessee
Unless you can meet the provision for existing feeders, 680.25 requires a conduit system for feeders.
For SPA's located at single family dwelling units, see 680.42(C). NM cable or any other method that includes a bare (but covered) equipment grounding conductor would be allowed to be run for the interior portion of the circuit.
For a "pool panel" you are stuck with other methods though.
James S.
Mesa, Arizona
A pool sub panel usually has an underwater light (wet niche luminaire) run from it. 120 volts underwater, and chest height of a person holding on to the edge, makes the CMP very nervous. They want you to be very careful with that ground.
That makes sense but wouldn't the GFCI be a better protection for some sort of short in the pool light?
GoldDigger
Placerville, CA, USA
Retired PV System Designer
I suspect that historically the no-NM rule came into NEC before there were GFCIs. Also a good solid ground will remain operational longer than the typical GFCI receptacle. Not sure how good, by comparison GFCI breakers are.
Yes, and there's a #8 bond wire inside the niche and a bond wire on a lug on the outside surface of the niche. Each is there for a different catastrophic failure.
Besides, old GFCI receptacles used to fail and remain hot.
James S.
Mesa, Arizona
Ah, makes sense. Thanks guys.
