Is directly connecting a garbage disposal with NM cable code compliant?
The NM cable is exposed under the cabinet between the wall and disposal.
Why not terminate it in a handy box and use a flexable cord and plug?
It's done like that often in my area. It depends on whether or not your inspector sees the romex as subject to damage.
Some disposals are designed to install a using a cord and plug. Many will argue that if the disposal is not listed to be cord connected, then you can't connect it that way.
It is a existing disposer (in my house), and that's the way it was connected when the house was built. I was basically just wondering if it was installed per code to start with. I have found other code violations in my house.
I have to replace the disposal because it used to refuse to start sometimes, and now it trips a breaker every time I try to use it.
I think the flexible cord and plug would be a much better way to connect it.
I have seen them like that and assumed it was a violation. I personally like the idea of being able to unplug it as a form of disconnect.
