Cleveland Apprentice
- Cleveland, Oh
Hello,
I replaced a line thermostat on an attic exhaust fan a few weeks ago for HO. At the time of the install, it was cool so I tested the thermostat by turning it down to the minimum setting (60 degrees if recall correctly) to see if fan kicks on. The fan did kick on, so I changed the setting at 100 degrees and left. Recently, the HO called me and said that the fan does not run on hot days, but during the night when the temperature starts to drop, the fan kicks on until it gets hot outside again. The thermostat is operating the exact opposite the way it should and I don't understand this. I don't believe the thermostat is defective because it's brand new. There are only two black wires to the thermostat and doesn't matter which is the line or load per the instructions. Has anyone else encounter anything like this? Thanks.
