tahir mehmood
- qatar
august sir;
once again i need your help regarding a problem with a motor. hope you will share your precious time. sir we have a 110 KW pump motor run by a 132 KW VFD. The supply voltage is 415 V, three phase,60 HZ.Motor insulation class is "H".The motor is delta start and the phase sequence is red,yellow,blue.The full load amperes of the motor are 188 amperes. the set points for the currents in vfd are 187 amperes. first this motor pump was taking 167 amperes and 170 amperes. but now it is taking 184 amperes and 183 amperes. we changed the grease of the motor and oil of the pump also but it is taking the same amount of currents. we did the megger tests of it, the results are as under:
coil insulation test to ground = >1000 M OHMS i.e infinity
coil insulation resistance = 0.08 OHMS.
coil to coil insulation resistance = >1000 mega ohms i.e. infinity
cable insulation resistance is also ok
Also the voltages and currents which we are taking at the output of vfd are:
R Y B
187 A 180 A 181 A
we have checked the current unbalance which comes less than 5% according to NEMA standards.
The voltages at the output of vfd are:
R/Y Y/B B.R
460 V 464 V 466 V
we have checked the unbalance voltages which comes less than 1%.
Also we have checked the motor by changing the phases in the terminal box. i.e. we changed the red phase with yellow, yellow with blue and blue with red, the rotation of the motor was the same as previous and we got the results as:
B R Y
186 A 180 A 181A
We compared all the currents with before phase change currents, so we got a result that the cause of unbalance is in the electrical system. but that unbalance is with in 5% so its not an issue.
This pump motor when runs for 8 to 10 hours then it shows the "inhibit option on vfd" and gets tripped. we did all the electrical checks which shows that the motor is healthy. now i need your help that what shall we do with the motor so that it comes to healthy stage.
one more thing which i think is to decouple the motor and run it without load, but for that i need your help as i am confused that without load how much current the motor will take, i need the answer of this question. and the second thing is that why the motor is showing the inhibit option on the vfd, whether because of over current or over heat, since the class of motor is "H" so i think its not getting tripped because of overheat. also please tell me which other checks or tests we need to rectify the motor problem.
R Y B
187 A 180 A 181 A
R/Y Y/B B.R
460 V 464 V 466 V
B R Y
186 A 180 A 181A
