- New Jersey
- Journeyman Electrician
Have a 200kw natural gas CoGen turbine used to generate electricity and to heat water with a heat exchanger via the turbine exhaust. The turbine uses a 480/277 volts output to a disconnect switch mounted on the wall within sight. The disonnect is wired with the turbine output to the "load" side of the disconnect (fuses). This means that with the disconnect OFF and the turbine running that the fuses are energized. Since the line side of this disconnect is connected to a switchboard the switch has two sources of power.
The manufacturer has stated that this is code compliant. We would like an auxiliary switch within the disconnect to shut down the turbine when the disco is opened. We're being told that it's not required. Anyone have any thoughts or code issues with this setup?
