srinivasan
- Bangalore,India
Our designed fan has following parameters,
static pressure = 110 mmWg;
Volume =3500 CMH;
impeller thickness = 5 mm;
motor capacity =12.5 hp/9.3kw;
rated current =17 amps;
efficiency =88.8%;
power factor = 8.5;
coupled drive motor;
pole= 4;
maximum speed @110 mm WG =1460 rpm;
Due to wrong calculation, our persons made a mistake in design of fan with above parameters instead of getting 360 mmWC.
Please give suggestion to re design the fan to achieve 360 mm WG and also clarify ,
1) If we increase the speed the motor by changing the pole of the motor , what is result for pressure.
2) Since it is coupled drive motor, We can not change the motor alone, Am i right?
3) If we increase the speed, Which are the MOC thickness will change?Please give suggestion with out changing the full fan design.
Thank you.
Volume =3500 CMH;
efficiency =88.8%;
power factor = 8.5;
pole= 4;
Thank you.
