Hello, I seem to be confusing myself when trying to figure out fuse sizing.
I have a Isc x 1.25 = 207.9A. Isc x 1.56 = 260A.
The inverter I am using has fuse sizes 250A, 315A, etc. Note there is no 300A available.
I have gone through the entire sizing exercise and determined that I need to go with a 315A OCPD and 500kcmil aluminum conductors. I am trying to see if there are any code violations in using a 250A OCPD instead.
Per NEC 690.8(B)(1)(a), the OCPD is required "To carry not less than 125 percent of the maximum currents . . ." I understand that this refers to the 1.56 x Isc number, but why is carry the verb that is chosen? Further down in (d) it specifies the rating or setting is in accordance with 240.4. 240.4 essentially requires that the derated ampacity of the conductor be less than the next higher standard OCPD rating. To me, 240.4 is the only thing that matters when it comes to OCPD rating, and it is setting a maximum, not a minimum. What is 690.8(B)(1)(a) getting at with "To carry" ?
I am probably reading too much into this, but I appreciate anyone setting me straight.
