sparkync
- North Carolina
I am running outlets for a game room for kids. Each machine will pull 3 amps. Each receptacle will have 2 machines plugged into it, making 6 amps per outlet. I am planning on putting 2 outlets on a 20 amp. circuit. According to code I can run a "shared neutral" if I place the circuits under a double pole breaker. Under these circumstances, is that what most of you would do to save wire?? Thanks a lot...
