PowerLimited
- Bugtussle
Would there be any wiggle room in the code to have a condensate pump itself, that is a condensate pump associated with air conditioning equipment, NOT having a disconnect/switch within sight of the condensate pump (only switch would be out-of-sight circuit breaker ? ( in other words...except for the condensate pump, which has no disconnect/switch within sight, the air conditioning equipment otherwise has a disconnect within sight. When the disconnect, within sight, for the air conditioning equpment is shut off, the condensate pump stays hot. ).
