Strathead
- Ocala, Florida, USA
- Electrician/Estimator/Project Manager/Superintendent
A job I am doing requires proximity sensors to indicate that the garage roll up doors are closed for security purposes. NEC 511 requires the entire floor space below 18" to be class 1 division 2. Oddly enough I am being told that no one makes the drive over switches that are typical for this application classified. You can't use a side mount switch because it would protrude and be above 18", so the door would have to stop before the magnet rolls up in to the door at the top. I can only assume that this is being overlooked across the country, because I don't think we are interpreting the code incorrectly. Has anyone run across this situation, or have a solution?
