Everyone,
Has anyone ever serviced (or installed) fountain lights? I have a customer that has submersible box with 10 corded lights coming out of it. One of the lights has cracked lens and is causing the GFCI breaker to trip.
My plan is essentially to order some potting compound and remove the bad light and cord (they won't miss one light). Then install a plastic KO seal and re-install the compound. Does this sound reasonable? How hard will it be to remove the old compound? Are the cords spliced in the box with wirenuts or is it usually a factory assembly? Thanks, I've never worked on these before.
Also, I've noticed the old box is mounted on a piece of rigid that is corroded. If that is part of the problem, I have no clue how to fix it. I noticed the code requires this to be brass now.
