Have a question regarding GE system. If a copper water line is used as a grounding electrode and there is footing re-bar also available, does there still need to be a driven rod? What would the proper system consist of if water came in as plastic
and the re bar is present? I'm working in two different municipalities, one is requiring the driven, the re bar, and the copper water, the other is requiring any 2 of the three I named. To my knowledge neither of the two AHJ's are doing any type of Ohm's check on the system. In either of the scenarios I've listed, the footing re bar is always present. Thanks much.
