green2012
- highland park, il
I went over this a few times and wiring looks good. This is a pipe and wire installation. I piped from the main panel to the exterior of a home and mounted a spa disconnect. Pulled 2 hots, a neutral, and a ground. When I finished landing all the wires in the disconnect, I started testing for any unwanted continuity before I turned on the breakers. I tested positive continuity between neutral and ground conductors. Is this normal? The main panel nuetral is bonded to the box. I know Im suppose to get continuity between neutral and ground at the main panel and all the ground wires can land on the neutral bar at this panel. Is this why Im reading continuity at the disconnect?
