Power for pellet insert
Bsowden1224
New member
Oxford,ma
I have been unable to find a definitive answer on this subject, so I hope you can help. My customer is getting a pellet stove insert installed and doesn't want the cord showing. I was wondering if I could run a mc through the ash dump and hardwire the stove by removing their factory cord. I wanted to originally install a plug but it technically isn't accessible unless you were to take off one of the side panels . Any help would be great
Gregg Harris
Virginia
Electrical,HVAC, Technical Trainer
Check the products listing, it may allow it to be hard wired
ActionDave
Chief Moderator
Licensed Electrician
I would do it if I had to. May violate some U.L. thing so proceed at your own risk.
If this is the only problem then I don't think you have a problem. There is no problem with a recpt, not being readily accessible unless it is a GFCI.
junkhound
Renton, WA
EE, power electronics specialty
Better use 260C rated wire if you run thru the ash dump - hot embers possible.
Even then may have a problem even with TFE insulation and nickel plated wire.
GoldDigger
Placerville, CA, USA
Retired PV System Designer
I assume that the OP is referring to the now unused ash dump of the existing fireplace into which the insert will be installed. I do not think that any embers will exit the bottom of the insert into the area around the old ash dump. It would just be a way of getting wiring into the fire pit area without drilling or removing old firebrick or brick.
The clearance area under the insert may still get hot, so check the manufacturers data before running any wiring there.
