caculating j box size
SparkyRules
United States
I want to run 4-4" conduits in one side of a j-box (314.28-(A)(1)=8x largest raceway or 4"x8=32 " minimum. However out the other side I want to attach a 8" duct(Art376). would the 8" duct be considered a raceway if so then I would need 8x8 or a 64" J box? Comments?
kingpb
SE USA as far as you can go
Engineer, Registered
I assume the 4" conduits are carrying 4 sets of parallel conductors the duct you mention is actually wireway.
Therefore the MINIMUM distance from the side where the conduits enter to the opposite side with the wireway is the 32" you mention.
However, I think a question arises that the cables can only take up 20% of the cross sectional area of the wireway. Hence, 8" x 8" = 64 sqin; 20% is 12 sqin
If the 4 x 4" conduits are all filled to maximum 40%, then you have 20 sqin of conductors and the 8" x 8" wireway is not sufficient.
Something to consider.
jusme123
NY
JW
...a wireway is considered a raceway.
what is being pulled through the 4" conduits?
