marcjr
- belo horizonte, brazil
Hi. I have a number of circuits running in a bank of underground ducts. This bank runs 38" below the surface of the ground through its length, except for a small part (35 ft) that runs 45" below the surface in order to avoid interference with water pipes. The question is: can I disregard this deeper section of the duct bank and calculate the cables as if they were running 38" below ground throughout the duct bank? That is, can I consider longitudinal heat flow will absorb the additional heating generated in these 35 ft of cable?
