pump on GFCI
Gaffen99
new jersey
I have a small landscape pond in outside courtyard. I'm being told that after a year of service the pump starts to trip the gfci outlet sporadically. Someone once said that a certain motor will do this after it breaks in and ages, but after a year? Anyone can help?
Gregg Harris
Virginia
Electrical,HVAC, Technical Trainer
On a receptacle or breaker?
Gaffen99
new jersey
Its an outlet. I am looking for a solution to fix the problem, maybe a hard wired disconnect. But I would like to know why this keeps happening every year.
iwire
Massachusetts
The pumps are cheap, water gets in the electrical areas and it trips.
I would not eliminate the GFCI and I would not hardwire it.
electricman2
North Carolina
Retired Electrical Contractor
I have a small pump on an outdoor fountain on a GFCI. About 5 years plus with no problems. Get a high quality pump and you should be OK.
sparkycoog
Texas
The cheapest solution is to replace the GFCI and make sure and seal the outlet in case water is getting in. If it still trips, then change the pump. I would not eliminate the GFCI either for something like this that can end up killing someone.
Gregg Harris
Virginia
X2
Dennis Alwon
Chapel Hill, NC
In my experience never once has replacing the gfci ever worked. I only do it to appease the home owner however a new pump is the solution in most case. I agree with electicman2 about a quality pump. I have seen owners replace pumps almost yearly until they finally get the idea and get a quality pump. As soon as the seals wear out the gfci will trip
GoldDigger
Placerville, CA, USA
Retired PV System Designer
New and quality pump it is. Thanks. But, is there any truth to the brushes of the motor wearing and causing the trip?
Very little. Brushes worn to the point that they started grinding into the copper from metal to metal contact, or were no longer held in good contact by their springs could cause a signature that could trip an AFCI. But there is no way it could cause a ground fault in a properly insulated pump unless the conductive dust from both the brushes and ground-down copper from the commutator somehow created a current path to a grounded part of the motor frame.
GoldDigger
Finding a landscape sump pump with a universal motor may not be the same as capturing Bigfoot but certainly would be like catching a live giant squid.
Note that this is although the OP described a landscape pond, elecricalman2 also introduce the "small outdoor fountain" which might have a fish tank pump rather than a landscape sump pump. I agree that the best and cheapest way to build it will be with an induction motor or even buzzer diaphragm, so that is all you are likely to see.
There are DC pumps available for RV and other use (typically low voltage though.)
But in any case, I agree with you that wear on the motor brushes could only be a contributing problem if it had brushes in the first place! And probably not even then. :)
