JazzyJoel
- Petaluma, Ca, USA
A new "installer" low balled the building management, they promosed a 1 day install we have now endured 5 days of install, they are not following any NEC guide lines, no permit either... Reasons why im inquiring about wall plate location: They have drilled a hole into the drop ceiling tile, punched a RJ45 wall plate terminal then crammed the plate-jack between the tile and the tile-track, there is no box to protect the wiring, no support of the cat5 wire, it is in a NON-Plenum space... However the installer did not use plenum rated cable either... the jack plate is just crammed between the tile and the track no screws, rivets or other means of securing..... there are 36 offices in the building all of which are now wired the same way !!! not to mention the tile is located 8' off the floor the only way to access the T-1 line is through this rj45 jack on the ceiling tile!!!! looking for code section the deals with this, so i can have a talk with the installer...
Thank You,
Joel
Thank You,
Joel
