Wiremold outside 45^ corners
wyreman
SF CA USA
electrical contractor
How do you do?
I got a shoe to bend the inside 45s
How do you do the outside 45s
Is there a filling?
I could use some flex connector but maybe looks bad
Thx
Sent from my iPhone using Tapatalk - now Free
wyreman
SF CA USA
I have that wiremold shoe for the inside
but not for the outside =0
It will have a big shepherds crook
GoldDigger
Placerville, CA, USA
Retired PV System Designer
Notch a triangle out of each sidewall of the wiremold and then bend? (Be sure to deburr the cut edges.)
May or may not be code approved, but it should work and look reasonably good if done in a workmanlike manner. :)
Or else take an outside 90 and bend it back to only 45.
Put a box or elbow connector on each side of the outside 45 deg corners and drill/fish flex between them inside the wall. Not as ugly as anything on exterior that doesn't fit snug around the corner.
gadfly56
New Jersey
Professional Engineer, Fire & Life Safety
How do you do?
Is there a filling?
Thx
Use their V5700F flexible section "for getting around difficult angles".
wyreman
SF CA USA
Sorry guys????
That was a great suggestion but it looked to me like far too much unnecessary work
so I asked owner and inspector if we could just miss layout in those existing walls that had never been disturbed
Both were amenable.
Problem solved by "nothing done"
