factoryrat
- Detroit
Today, at work, the millwrights welded metal guard railing to a metal framed work deck. They came to me and said the overhead fluorescent lighting went off. This overhead lighting hangs off a metal unistrut grid that attaches to the metal framed deck below, the deck they were welding on.
I went to the lighting panel and tried to reset the circuit breaker but it tripped immediately. Upon further investigation I found the circuit?s ground wire, that I believe, had got hot enough to melt through its insulation and through the branch circuit?s hot conductor?s insulation and cause a short. I fixed the problem and turned lights back on.
My question is how does arc welding on a steel platform cause a lighting circuit?s ground wire to pass current and melt its insulation, if that is what actually happened? Does anyone have any thoughts on this? Is there something wrong with the way the 120 volt lighting circuit is wired? Is there a way to avoid this problem in the future?
