Toros
- Tujunga, CA
Hi,
why 277v circuit breakers ara bolt-on,
why not snap-in??
why not snap-in??
Effectively their whole I-Line series is 'plug-in'.SQ D has 277V plug-in breakers, or at least they did.
Hi,
why not snap-in??
I was told that higher fault-current rating of the equipment will dictate how the equipment is constructed. So the higher the fault-current rated equipment will have more support for the bussing and bolt-in style breakers.
Although the I-line equipment is plug-on, it has this feature design:
Breaker connections
are ?blow-on? type.
Under high-level fault
conditions, the magnetic
forces developed force
the jaws together,
gripping the bus bar
more firmly. Heavy-duty
jaw connectors are
plated to ensure good
conductivity at the
contact.
Interesting!
The information comes from the manufacturer, it is part of their normal marketing literature.Ditto, I wonder where this thought originated from? Did it come frpm the manufacturer. Which working for 2 major electrical manufacturers for 18 year I would have thought that would have been part of the selling points. But there were none. Why are there 'bolted pressure switches' rather than basic fusible disconnect switches?
http://static.schneider-electric.us...ay/I-Line and I-Line II Busway/0600DB1004.pdf
