Acerock21
New member
- Ceres, Ca. Stanislaus
I am tapping an existing 500amp 480v feeder to feed a mcc with mostly motor starters. The feeder is parallel 500mcm alum. in 5" PVC 3ph 3w (2 x 500al/ph + 1 x #2cu gr). There are two 30amp breakers in the mcc that are going to feed packaging equipment from Europe. The vendor has requested a neutral for his equipment that will have no/minimal load, they just want a reference. I am going to attempt to pull a neutral through the existing conduit, what is the minimum size copper conductor that I can pull? Thank you in advance for your help.
