I get to bring a noninspected jacuzzi up to rigorous standard now.
Motor is installed so that gfi is inaccessible.
Its not bonded.
So I pull the motor out of the little hatch and ... have to cut the plumbing out to do that and... cant do anything else.
Everything is all tiled around and on the wall behind.
The other wall behind is way up in the air only accessible by rope.
I haven't been able to find a motor with a longer whip or hard wire config
That seems to be the only way to long up the wire and get it to the tile wall behind
but then the disconnect would not be within sight. Inspector seems ok with that.
Long story short, any thing I may have missed:
get a motor with a longer whip or hardwire - does the disconnect have to be visible?
keep 36" cord, and if so, then
Can I Cut the end of the sjo cord and land it in a gfi box and remain compliant? Somehow I doubt it, it's not a fluorescent fixture.
Otherwise I will have to build some kind of second access hatch in the tile wall=0
TMI:
Hard to describe, the photos may help.
http://flickr.com/gp/sfpow/22s892/
bonding w #8 to cold water
the old #12 went to the romex =)
Its not bonded.
TMI:
