This is first time in my life seeing this strikes, maybe i'm not used to, but really after this i know how the protection systems are requiredIs there any evidence that such strikes are an issue in buildings that have been constructed with a steel frame?
Every year there are multiple lighting strikes to the tall buildings in Chicago. I have not read reports of damage from the lightning strikes.
A friend of mine was taking pictures of a storm a while back and while he was sitting in his van lightning struck it and he got a picture of the strike from the inside!. It wiped out his radio, but otherwise no damage.
Probably no ear damage also because only low intensity lightning reach ground directly, if there are tall objects around. Low intensity lightning create low pressure sound waves not affecting the ear.How is his hearing?
How is his hearing?
CG (cloud to ground) lightning can occur with both positive and negative polarity. The polarity refers to the polarity of the charge in the region that originated the lightning leaders. An average bolt of negative lightning carries an electric current of 30,000 amperes (30 kA), and transfers 15 coulombs of electric charge and 500 megajoules of energy. Large bolts of lightning can carry up to 120 kA and 350 coulombs.[32]
Unlike the far more common "negative" lightning, positive lightning originates from the positively charged top of the clouds (generally anvil clouds) rather than the lower portion of the storm. Leaders form in the anvil of the cumulonimbus and may travel horizontally for several miles before veering towards the ground. A positive lightning bolt can strike anywhere within several miles of the anvil of the thunderstorm, often in areas experiencing clear or only slightly cloudy skies; they are also known as "bolts from the blue" for this reason.
Positive lightning typically makes up less than 5% of all lightning strikes.[33] Because of the much greater distance to ground, the positively-charged region can develop considerably larger levels of charge levels and voltages than the negative charge regions in the lower part of the cloud. Positive lightning bolts are considerably hotter and longer than negative lightning. They can develop six to ten times the amount of charge and voltage of a negative bolt and the discharge current may last ten times longer.[34] A bolt of positive lightning may carry an electric current of 300 kA and the potential at the top of the cloud may exceed a billion volts ? about 10 times that of negative lightning.[35] During a positive lightning strike, huge quantities of extremely low frequency (ELF) and very low frequency (VLF) radio waves are generated.[36]
As a result of their greater power, as well as lack of warning, positive lightning strikes are considerably more dangerous.
When I was a kid I was standing in the doorway of a friend's house when lightning struck a pole mounted transformer across the street. I don't know if I have ever, to this day, heard anything else that loud, and I have been to a Ritchie Blackmore's Rainbow concert.Probably no ear damage also because only low intensity lightning reach ground directly, if there are tall objects around. Low intensity lightning create low pressure sound waves not affecting the ear.
The idea that low frequency waves made by a speaker "develop" over distance is a myth. In some rooms it may seem that way because of reflections and standing waves but in free space the intensity of low frequency sound falls off exponentially with distance just like any other sound.As the acoustic wave gets farther away, the frequency lowers and imparts more of it's energy to the surroundings. Like how a sub woofer acts.
I'm a bass player, BTW. Low frequency sound is my domain.
I apologize for my careless and misleading remarks. I am pond scum.And you should also be aware that sound intensity (acoustic watts per unit area) falls off as the inverse square of the distance from a point radiator.
Calling the falloff exponential is only correct.if the distance appears in the exponent of the expression.
It is all too common to use the term "exponential" for anything that falls off or increases faster than just geometrically (first power), but that is both careless and misleading.
JMNSHO.
PS: At bass frequencies in open air almost anything acts like a point source, unless it is acting like a dipole instead (open backed speaker, for example). And a dipole really sucks for bass.
That might even be exponential.
Tapatalk...
Low intensity lightning creates relatively low pressure sound waves. But it does not mean there is no noise. It will feel like the sound of a big cracker going off.Quiet lightning. :slaphead::lol:
The highest intensity ground to cloud lightning can happen,if there were no nearby tall object to intercept it. In other words, it takes place on open ground.Ground to cloud lightning can be the highest intensity of all.
If that is not true, there is no sense in providing lightning protection.
