Ground Bond Tester
fifty60
USA
I am in need of a ground bond tester like this one here: http://compwest.com/GFM200AC.html
I would rather not purchase the meter, but would like to rent. Does anyone recommend either a low cost 200A ground bond tester or a place where I can rent the equipment?
brian john
Leesburg, VA
You want field test equipment not lab grade, (I WOULD THINK)
A Ductor/DLRO (digital low resistance meter)/micro-ohm meter, Electrorents.
Then come in 10 amp, 100 amp, 200 and up to 600 amps.
dereckbc
Plano, TX
What you are looking for is a DLRO portable model, not bench. They use 1, 10 and higher amp current reference in a 4-point Wein Bridge. The current is precision controlled by a current supply on two points, then the voltage is measured by the other 2 point. Result is a resistance reading like any Ohm meter does. Difference is your DMM Ohm Meter is only accurate above 10 Ohms, while a 10 amp DRLO is accurate down to 1 micro-ohm.
Portable field models are not cheap, and bench units are even higher priced.
