KJLanger
- St. Paul, MN, USA
I have some questions regarding the interpretation of Article 430.75 as it applies to the attached control circuit. Our motor control circuit is a motor starter with a 24VDC coil, controlled by a PLC output. We monitor the states of the DIS, the MCP, and the motor starter. If the DIS, or MCP is turned off (open), our program will not allow the motor starter output to turn on. Would this be considered as "disconnected from all sources of supply"? If I used safety I/O instead, would it then be considered disconnected?
I have seen where an auxiliary contact from the DIS is run in series between the PLC output and the motor starter coil, to supposedly comply with this article, but I don't understand how that addresses the article any better than the method I use above. Couldn't the motor starter still be mechanically activated allowing the presence of high voltage at the line side of the disconnect?
Is the intent of the article to ensure no voltage is present at the line side of the DIS? If so, shouldn't logout/tagout be employed at the MCP to prevent this? It seems like the disconnecting means to the motor control circuit in my example would be the MCP, not necessarily the DIS, in which case the 24VDC motor starter coil power should be disconnected when the MCP is open, but not necessarily the DIS. Can you comment on that?
If the intent of the article is to ensure no voltage whatsoever is present at the line side of the DIS, then power to the DIS aux contacts should also be removed, correct?
Thank you,
Thank you,
