Phasor theory and nonlinear loads
It is understandable that one would ask such a question, because three-phase calculations are not easy. However, the question as asked admits no straightforward answer. There is no "total current." There is a neutral current, but one doubts that the neutral current is the answer you seek.
The full answer to your question involves phasor theory, which is nontrivial to learn. See for example T. Wildi, Electrical Machines, Drives and Power Systems, 3rd ed., Ch. 8., 1997.
Of more practical interest may be what the NEC has to say on the question, in particular in article 310.15(B)(5), 2011. The NEC however will not help you to understand what is going on here, nor why your question regrettably does not quite make sense.
I wish that it were possible in a brief format like this to give you a more informative answer. Other than to caution you that you may need to take into account the matter of nonlinear loads to get an accurate answer to your question -- especially if a VFD is involved -- and to acknowledge that you may not know what a nonlinear load is, why, if you lack the time, preparation and/or aptitude to study the relevant electrical theory in considerable detail, then all I can do is to direct you to an engineer or, if this is not realistic, to wish you luck.
