Weren
New member
- pittsburgh, pa, usa
Hello, I am doing some wiring for a Hospital that is installing a wheelchair lifting system. The wheelchair lift company wants me to install a 2 pole 30 amp disconnect for them. They want 1 pole to have a 120volt circuit and the other pole be used to disconnect a 24volt battery backup that they are installing. So both sources will be disconnected when the switch is off. Is this allowed code wise to have 2 different sources in this disconnect? If not could you please reference a code section. Thanks!
