In the past I have always run parallel 4/0 copper from the transformer to the meter on the house. Then 4/0 copper from the meter to a 400 amp disconnect in the basement on an outside wall. Someone mentioned that I could use 2/0 copper in parallel instead. Does anyone here have anything to support this suggestion? I've checked the 2014 code which my state (Mass) is using and could not find anything supporting this setup.
