- NE Nebraska
I agree and that did cross my mind when posing before. Not every time is the end within the wall though, or you get guys that need to use a RMC out of top of meter for a mast that will support a service drop but they don't have a threader for 1.25 to 2 inch and want to instead run EMT out the load side of meter, then they would be using EMT in both sides of the LB.If the right angle end of the LB is inside the wall and sealed at the wall surface, you would not need the EMT connection to be watertight.
I realize this taper thread and straight thread thing is maybe technically wrong, why did they make these things interchangeable in the first place if they are not intended to be used together?
Biggest concerns brought up are water tightness or bonding effectiveness. Does anyone have any indisputable proof of either being a problem? By indisputable I mean can you prove the water inside a raceway came through the threads or possibly from condensation or other entry point, or that a failure of bonding was because of a mismatch in threads and not that a fitting wasn't ever tight in the first place.
