Buck Parrish
- NC & IN
I have a supplemental 12 v deep cycle marine battery feeding a 2000 watt inverter, a 450 watt inverter and various 12 v lights.
I have an onboard charger to charge the 12 volt deep cycle marine battery.
It's not connected to the starting battery or generator/alternator.
Soon after I installed a 6 watt solar trickle charger my on board charger quit working. I don't think it was immediate, but not sure how long it was before it quit working.
The lights come on but the charging mode light does not.
All the wires are connected to the marine battery. All the time. via fuses / switches
Do you think the solar panel is confusing the automatic on/off sensor on the onboard charger?
Or do you think the 6 watt solar panel fried a circuit on the onboard charger?
Perhaps it was a coincidence ?
My onboard charger is relatively new. It's a dual bank on board marine charger. 'Pro Sport 8'
Both leads two blacks and two reds are tied together to feed the one battery (bank) as suggested by the manufacturer.
Any input would be appreciated, thanks.
