- Licensed Electrician
You got it. Hard to see from the angle but it's also at towards the front of the motor.Pecker head on the right instead of the left?
Well at least they were close to right..You got it. Hard to see from the angle but it's also at towards the front of the motor.
I have had to switch end bells and spin the rotor around to get a motor to fit but this is the first time I have seen one from the factory that way.
It's a replacement IEC motor. The original had the peckerhead on top.
Odd only in the sense it is less common in U.S. NEMA floor-frame motors commonly have the pecker head on the left.I haven't wired motors like that in a few years now. But did do a search. Some peckerheads are on left some right some top. Why is ths on the right odd ?
If it was made south of equator it will turn wrong direction if used in North America:happyyes:
http://www.reliance.com/mtr/aplmnt.htm
Close enough. It fit fine.Well at least they were close to right..
Now that is really odd. What kind of motors are they?In my experience I have seen about an equal mix with those on the right having a slight edge.
