Since we are talking about electrical provisions I would say a manufactured trailer with an electrical system including electrical supply provisions.
Which is a fine opinion but no more than that. Job trailer is undefined term.
No, but I took it that we were discussing the typical office type job trailer.
You mean a manufactured building?
Somewhere I have a picture of the tag stating such. I will try to find it.
I would recognize that a manufactured mobile home that was designed to be used as a dwelling could be placed on construction site and be used as a job trailer.
And I agree it could and if it is 550 applies.
I would also recognize that this section addresses manufactured mobile homes supplied by 120/240 volt systems that did not have all the provisions or circuitry that would qualify there use as a single family dwelling could likewise be used as a job trailer on a construction site.
I don't see that at al,l but to me that is also not on point.
I would also recognize that 550.4 addresses manufactured mobile homes that could be supplied by other voltage systems such as 480/277 though not specifically called out in this section the supply voltage on these manufactured mobile homes was not limited to 240/120
Respectfully I do not see that as having anything to do with this discussion.
I would be left to conclude 550.4 only addressed manufactured mobile homes not intended to be dwelling units because of circuitry and other dwelling provisions where being manufactured as offices, clinics, job trailers and so on. when supplied by 240/120 volt system
Respectfully I see that as your own creation and not in 550.4
I would go back to 550.1 and struggle with how I get from 550.1 to include 550.4 .
There is no struggle if you only apply 550.4 to mobile homes and not try to extend its reach to trailers that are not mobile homes.
The problem with that is each state can regulate what is or is not tagged as a manufactured building
How is that a problem?
Often I see multiple acceptance state acceptance stickers on these units.
From the hand book commentary article 545
?Manufactured homes are built on a chassis and installed on site with or without a permanent foundation. Manufactured buildings are generally constructed within a factory or assembly plant and then transported to the building site.
They are not built on a chassis and are designed to be installed on a permanent foundation. ?
This is not the only example of the handbook overstepping the code rules.
the code cannot be concerned with what each state individually does
I agree, yet that changes nothing. States deviate from the NEC all time.
