Was hired to replace an old noisy bath fan light. Cheap builder special. Gave price over phone not much and mentioned if there was access from the top and the old one came right out and the new one went right in. Well of course it didn't but wasn't too major so the new one went in.
The question is.
I turned off the two switches at a four switch gang box to work on the fan/light. Removed the 3 wire from the old unit. Mounted new unit. Slid 3 wire into new unit. As I was setting up for splice the white wire hit fan chassis and sparked. Yep white's hot and black and red were switched neutral.
Opened 4 gang box the other 2 switches fed a vanity and shower light. Colors were right. There was a bx to rx splice box in attic area by fan/light. Opened it colors are right. Mentioned this to home owner and he said a handyman replaced a light in the hall and mentioned about reverse polarity.
So I replaced the fan/light. I mentioned I could look to correct the problem which could take ten minutes or several hours.
They asked if it was dangerous as it's been that way since the bathroom was done over twenty years ago.
I mentioned it could be. To realize the switch doesn't de energize the lights (including the shower) and not to change the bulb barefooted. And asked again if they wanted me to locate the problem. No yes.
On the way home called again to thank them for the work and to ask them again if they would like me to look into the problem. No yes.
So how liable am I ?
Should I have disconnected the wires to the fan/light that I installed and unless I fix the problem I'm not going to hook it up.
Should it have fallen into the "as long as the other comes right out and the new goes back in" or should I have looked for the problem as it was part of the fan install. Or lose a little sleep over it but it will be ok for another 20 yrs and nothing will happen. Argh.
Did a little work on a fountain area last year summer. Charged for material and not my rate for several hours to get lights on at this area. Rusted tripping gfci receptacle. Dirt water filled light sockets. Boxes at dirt level rusty dirty wet ... Shorted pump motor. I replaced gfci. Replaced sockets and cleared hot to ground and neutral to ground shorts. Mentioned to owner about the rusting boxes with existing rusted in switches. The mushroom effect. The more I touched the more that would need to be replaced. So she was up and working.
Got a call yesterday that it is not working again. I mentioned that I would dig that area up expose the wiring to that area and rewire everything, new boxes, switches etc.. as I couldn't promise if I tried reworking that area as I did before all would be fine and she wouldn't be calling me back again in a couple months.
I gave her a "ball park" what she might be looking at. Nothing steep but she mentioned that was to much where all she wants is " just a light " to light her fountain.
We both decided it best she call someone else.
I called her back an hour later.
I told her I'll come out at no expense and try to dry things out one last time the way it is.
Do a lot of you guys do free work ? Argh.
Thank you for letting me vent.
The question is.
